Contents
1 Introduction
1.1 What Is SpamSieve?
1.2 Identifying Spam
1.3 Integration
1.4 Main Features
1.5 Why Choose SpamSieve?
2 Installing and Updating
2.1 Requirements
2.2 Installing SpamSieve
2.3 Updating From a Previous Version
2.4 Reinstalling a Fresh Copy
2.5 Uninstalling SpamSieve
2.6 Security & Privacy Access
2.6.1 Granting Full Disk Access
2.6.2 Granting Automation Access
2.6.3 Troubleshooting Privacy Access
3 Using SpamSieve
3.1 Setting Up Apple Mail
3.2 Setting Up Apple Mail (Plug-In)
3.2.1 Enabling and Updating the Apple Mail Plug-In
3.3 Setting Up Airmail
3.4 Setting Up GyazMail
3.5 Setting Up MailMate
3.6 Setting Up MailMaven
3.7 Setting Up Mailsmith
3.8 Setting Up Outlook
3.9 Setting Up Outlook (Large Inboxes)
3.9.1 Outlook IMAP/Exchange Account Rules
3.9.2 Outlook Gmail Account Rules
3.9.3 Outlook POP Account Rules
3.10 Setting Up PowerMail
3.11 Setting Up Gmail, iCloud, Yahoo, AOL, or Other Web Mail
3.12 Setting Up Other Mail Clients
3.13 Do an Initial Training
3.14 Correct All Mistakes
3.15 SpamSieve and Multiple Macs
3.16 iPhone Spam Filtering
3.16.1 Converting Your Apple Mail Setup to IMAP
3.16.2 Recommended Mail Hosts
4 Customization
4.1 Allowlisting Previous Recipients
4.2 Automatically Deleting Old Spam Messages
4.3 Setting Up a Spam Filtering Drone
4.3.1 Setting Up an Apple Mail Drone
4.3.2 Setting Up a MailMate Drone
4.3.3 Setting Up an Outlook Drone
4.4 Customizing Using AppleScript
4.5 Apple Mail Customization
4.5.1 Spam Message Colors in Apple Mail
4.5.2 Color Rules in Apple Mail
4.5.3 Processing Messages Before SpamSieve
4.5.4 Setting the Junk Mailbox in Apple Mail
4.5.5 Only Filtering Certain Accounts
4.5.6 Rescuing Good Messages Caught By a Server Filter
4.5.7 Filtering Spam During Power Nap
4.5.8 Keeping Spam Messages Out of Gmail’s Archive
4.6 Outlook Customization
4.6.1 Turning Off New Outlook
4.6.2 Duplicate Outlook Calendar Invitations
4.6.3 Filtering Other Outlook Folders
4.6.4 Spam Message Categories (Outlook)
4.6.5 Separate Spam Folders for Each Account (Outlook 2011)
4.7 Hiding Special Gmail Mailboxes From IMAP
5 Menus
5.1 The SpamSieve Menu
5.1.1 About SpamSieve
5.1.2 Software Update…
5.1.3 Purchase…
5.1.4 Mac App Store
5.2 The File Menu
5.2.1 New Rule
5.2.2 Import Addresses…
5.2.3 Reset Corpus…
5.3 The Message Menu
5.3.1 Train as Good/Spam
5.3.2 Mark as Flagged
5.3.3 Open in External Viewer
5.4 The Window Menu
5.4.1 Corpus
5.4.2 Statistics
5.4.3 Log
5.4.4 Blocklist
5.4.4.1 Rule Columns, Locations, and Match Styles
5.4.5 Allowlist
6 Settings
6.1 Settings ‣ Filters
6.1.1 Use corpus messages
6.1.2 Use macOS Contacts
6.1.3 Catch spam sent from my own addresses
6.1.4 Use Outlook/Entourage contacts
6.1.5 Use SpamSieve allowlist
6.1.6 Use SpamSieve blocklist
6.1.7 Use Bayesian classifier
6.1.8 Train SpamSieve allowlist
6.1.9 Train SpamSieve blocklist
6.1.10 Train Bayesian classifier
6.1.11 Auto-train as needed
6.2 Settings ‣ Notification
6.2.1 Play sound
6.2.2 Bounce Dock icon
6.2.3 Keep bouncing
6.2.4 Show number of new good messages in Dock
6.2.5 Flash PowerMate
6.2.6 Notification Center shows
6.2.7 Uncertain spam messages
6.3 Settings ‣ Apple Mail
6.3.1 Settings ‣ Apple Mail ‣ Setup
6.3.1.1 Check inboxes for new messages not sent to Mail extension
6.3.1.2 Install Apple Mail Plug-In
6.3.1.3 Uninstall Apple Mail Plug-In…
6.3.2 Settings ‣ Apple Mail ‣ Filtering
6.3.2.1 Move it to the Trash if the spam score is at least
6.3.2.2 Mark it as read
6.3.2.3 Color the background according to how spammy it is
6.3.2.4 Filter spam messages in other mailboxes
6.3.2.5 Add green flag to unread good messages
6.3.3 Settings ‣ Apple Mail ‣ Training
6.4 Settings ‣ Outlook
6.4.1 Settings ‣ Outlook ‣ Setup
6.4.2 Settings ‣ Outlook ‣ Filtering
6.4.3 Settings ‣ Outlook ‣ Training
6.4.4 Settings ‣ Outlook ‣ Outlook 2011
6.5 Settings ‣ Other Clients
6.6 Settings ‣ Storage
6.6.1 Prune full message data in log
6.6.2 What can I do if the corpus is damaged?
6.6.3 What can I do if the log is damaged?
6.6.4 What can I do if the rules are damaged?
6.7 Settings ‣ Advanced
6.7.1 Show menu bar icon
6.7.2 Show Dock icon
6.7.3 Quit when mail client quits
6.7.4 Spam-catching strategy
6.8 Esoteric Preferences
7 Frequently Asked Questions (FAQ)
7.1 Why is SpamSieve not catching my spam?
7.1.1 Checking the Apple Mail Setup
7.1.1.1 If Apple Mail Is Running Slowly
7.1.1.2 If Apple Mail Is Running Slowly (Mail Plug-In Setup)
7.1.1.3 If Apple Mail Doesn’t Check for New Messages Automatically
7.1.1.4 If Apple Mail Shows an Error When Moving Messages
7.1.1.5 Duplicate Apple Mail Accounts
7.1.2 Checking the Apple Mail Setup (Plug-In)
7.1.2.1 If the Apple Mail Plug-In Doesn’t Appear in the List or Doesn’t Stay Enabled
7.1.2.2 Resetting Mail’s Private Plug-Ins Folder
7.1.2.3 If SpamSieve Tells You the Apple Mail Plug-In Isn’t Loading, But It Is
7.1.3 Checking the Airmail Setup
7.1.4 Checking the Entourage Setup
7.1.5 Checking the GyazMail Setup
7.1.6 Checking the MailMate Setup
7.1.7 Checking the MailMaven Setup
7.1.8 Checking the Mailsmith Setup
7.1.9 Checking the Outlook 2011 Setup
7.1.10 Checking the Outlook Setup
7.1.11 Checking the Outlook Setup (Large Inboxes)
7.1.12 Checking the Postbox Setup
7.1.13 Checking the PowerMail Setup
7.1.14 Checking the Training
7.2 What information should I include when I report a problem?
7.2.1 Sending in an Error Report
7.2.2 Sending in Screenshots
7.2.3 Sending in a “Sample” Report
7.2.4 Sending in Crash Log Files
7.3 Why is every message going to the Spam mailbox?
7.4 Why do good messages keep going to the Junk or Spam mailbox?
7.5 Can I delete spam messages that are in the Junk mailbox?
7.6 How should I configure the junk filter on my mail server?
7.6.1 Turning Off the AOL Spam Filter
7.6.2 Turning Off the DreamHost Spam Filter
7.6.3 Turning Off the Fastmail Spam Filter
7.6.4 Turning Off the Gmail Spam Filter
7.6.5 Turning Off the GoDaddy Spam Filter
7.6.6 Turning Off the HostGator Spam Filter
7.6.7 Turning Off the Hover Spam Filter
7.6.8 Turning Off the iCloud Spam Filter
7.6.9 Turning Off Microsoft Spam Filters
7.6.10 Turning Off the Proton Mail Spam Filter
7.6.11 Turning Off the Yahoo Mail Spam Filter
7.6.12 Turning Off Other Spam Filters
7.7 Why does a message disappear or go back to the Junk mailbox after I train it as good?
7.8 Does SpamSieve protect me from viruses?
7.9 Does SpamSieve stop Web bugs?
7.10 Does SpamSieve bounce spam messages back to the sender?
7.11 Does SpamSieve prevent me from receiving messages?
7.12 SpamSieve Application Questions
7.12.1 Why doesn’t my serial number work?
7.12.2 Should I download SpamSieve from this free site?
7.12.3 How can I copy my training data to another machine?
7.12.4 Does SpamSieve launch automatically?
7.12.5 Can I use SpamSieve with more than one mail program at a time?
7.12.6 Why does SpamSieve need to access my contacts?
7.12.7 How can I open the Library folder?
7.13 Apple Mail–Specific Questions
7.13.1 Why are Apple Mail inbox messages not being processed?
7.13.2 Why are other Apple Mail mailboxes not being processed?
7.13.3 Why don’t I see the SpamSieve commands in Apple Mail’s Message menu?
7.13.4 Why do good messages move to the wrong inbox when trained in Apple Mail?
7.13.5 Why do I see spam messages in my “Unread” smart mailbox in Apple Mail?
7.13.6 Why does the Spam mailbox in Apple Mail appear empty even though there’s a number beside it?
7.13.7 What can I do if my Spam or Junk mailbox in Apple Mail disappeared?
7.13.8 Why are messages marked as spam in Apple Mail but not moved?
7.13.9 Why do Apple Mail messages bounce back to the inbox after I train them as spam?
7.13.10 How can I rebuild Apple Mail’s database?
7.13.11 How can I reset Apple Mail’s junk database?
7.13.12 Can other Apple Mail plug-ins cause problems with SpamSieve?
7.13.13 What can I do if Apple Mail is crashing?
8 Legacy Mail Programs
8.1 Setting Up Airmail 1–3
8.2 Setting Up Entourage
8.2.1 Entourage Customization
8.3 Setting Up Entourage v.X
8.4 Setting Up MailForge
8.5 Setting Up Outlook 2011
8.6 Setting Up Postbox
9 Legal Stuff
10 Version History
