2.5   Uninstalling SpamSieve
Please Contact Us
If you are considering uninstalling SpamSieve because you’re having trouble using it or it doesn’t seem to meet your needs, please see this page or contact us at spamsieve@c-command.com. We’re happy to help get you up and running and always looking for suggestions for how to improve SpamSieve.
Temporarily Disabling SpamSieve
You can easily turn off SpamSieve if you don’t want your mail to be filtered for a while. For example, it can be helpful to disable spam filtering while you are troubleshooting your other mail rules.
Fully Uninstalling SpamSieve
In most cases, disabling spam filtering (as described above) will remove SpamSieve’s helper files, so that all you need to do to fully uninstall is drag the SpamSieve application file from your Applications folder to the trash. (If you’re uninstalling SpamSieve because the trial period is over, you won’t be able to access the Settings window to turn off filtering, but SpamSieve will automatically clean up the files when you quit the app.)
If you are using the old Apple Mail plug-in setup, you can additionally go to the Settings ‣ Apple Mail ‣ Setup window in SpamSieve and click the Uninstall Plug-In… button. This will offer to delete the SpamSieve rule(s) in Mail for you. (Note: If you are using multiple Macs and wish to continue using SpamSieve on one of the others, you wouldn’t want the deletion to propagate through iCloud, so you should instead uncheck the rule rather than deleting it.)
If you are using Outlook, you can delete any SpamSieve rules that you had created in Outlook’s Tools ‣ Rules window.
Other Mail Clients
Airmail
Uncheck the Use SpamSieve checkbox in the Advanced section of the settings (described in Setting Up Airmail).
Entourage
The scripts are located in the Entourage Script Menu Items folder inside Microsoft User Data (which is probably in your Documents folder). Go to Entourage’s Tools menu and choose Junk E-mail Protection… (or Junk Mail Filter in Entourage v.X) and re-enable Entourage’s junk mail filter.
GyazMail
Delete the SpamSieve rule (described in Setting Up GyazMail).
MailMate
Uncheck SpamSieve (described in Setting Up MailMate).
Mailsmith
Uncheck Use SpamSieve (described in Setting Up Mailsmith).
Outlook 2011
Delete the SpamSieve script files that are located in the Outlook Script Menu Items folder inside Microsoft User Data (which is probably in your Documents folder).
Additional scripts are located in the folder:
/Users/<username>/Library/Application Support/Microsoft/Office/Outlook Script Menu Items/
See the How can I open the Library folder? section for how to get to this folder.
Postbox
Choose Add-ons from Postbox’s Tools menu. Click the remove button next to SpamSieve Postbox Plug-in.
PowerMail
Go to the Spam filter assistant (described in Setting Up PowerMail).
Removing SpamSieve’s Data Files
You can optionally delete SpamSieve’s data files, which are stored at:
/Users/<username>/Library/Application Support/SpamSieve
/Users/<username>/Library/Preferences/com.c-command.SpamSieve.plist
/Users/<username>/Library/Logs/SpamSieve/
See the How can I open the Library folder? section. If you delete these files, you will have to re-train SpamSieve if you reinstall it.
