Contents  SpamSieve Manual  Technical Support
5.2.2   Import Corpus…
This imports the words in a corpus that was exported in XML format. This is the same format used by SpamSieve 1.x. Importing a corpus merges it with the active corpus. To replace the active corpus with the one you are importing, use the Reset Corpus… command before importing.
