Contents  SpamSieve Manual  Technical Support
5.3.5   Edit Log
This command opens the log file in a text editor such as TextEdit or TextWrangler instead of Console. This makes it easier to read and search large log files. You can control which editor SpamSieve uses by choosing Get Info in the Finder on a .txt file, changing the application in the Open with pane, and pressing Change All.
