I am having a problem now that I have upgraded to 1.3. I am trying to open my existing libraries and every time I do I get the message in the attached Screencap
http://c-command.com/forums/attachment.php?attachmentid=109&stc=1&d=1205958922
After I click, OK, the library fails to load. EagleFiler sits there.
I can create a new Library just fine, but I want to be able to import my old Library.
Any help as to how to get my old library to update properly would be very appreciated.
Do you see a progress bar? Are there any recent error messages in the log?
Well, you could always create a new library and then drag in the “Files” folder of the old library.
Michael_Tsai:
The progress bar is behind that window that says it’s trying to upgrade. I just disappears when I am done.
Will doing that also import my tags? That’s the main thing I don’t want to lose, I have a lot of them.
Working
Looks like it was a permissions issue, I gave the file access for everyone and it worked. Then I re-locked the file for everyone but me, and everything is working fine.
Yes, it preserves all the tags, notes, and other metadata.
