7.4   Why do good messages keep going to the Junk or Spam mailbox?
Normally, as soon as you train one message as good, SpamSieve will add the message’s sender to its allowlist. This means that SpamSieve will never classify future messages from that sender as spam. Also, by default, SpamSieve will never classify messages from senders in your contacts as spam. Nevertheless, there a several reasons why such messages might keep ending up in the Junk or Spam mailbox:
  1. A junk filter on the server might be classifying the messages as spam:
    1. This is especially likely to be the case if the messages are going to a different mailbox than the one that SpamSieve uses.
    2. The messages caught by the server will show up in Apple Mail’s message list with a white background and/or brown text, as compared with the messages caught by SpamSieve, which have a colored background.
    3. After you train the message as good, the Info section of SpamSieve’s Log window will show a Server Filter line that says whether the message was marked as spam by a server junk filter.
    In many cases, there is no visible switch to turn a server filter on/off, so it will be on unless you create a specific rule to turn if off. Please see the How should I configure the junk filter on my mail server? section about how to disable a server junk filter. Also, the Rescuing Good Messages Caught By a Server Filter section describes how to work around a server filter that can’t be disabled.
  2. Regardless of whether SpamSieve thinks a message is spam, the message can still end up in the Junk mailbox if you have created other rules in your mail client that move messages to the Junk mailbox. It is recommended that you disable or delete such rules. Also, make sure that your mail client’s built-in junk filter is off.
  3. Another computer that accesses your mail account may have rules or a spam filter that are moving the messages. If you are using SpamSieve and multiple Macs, a message trained as good on one Mac may not necessarily be treated as good on another Mac. Outlook, in particular, may keep moving the message back to Junk Email until you train it as good on the other Mac. You can look at SpamSieve’s log on each Mac to see which copy of SpamSieve (if any) predicted that a message was spam.
  4. If the messages in Apple Mail have an icon of a red circle with a slash, they were caught by Mail’s blocked mail filter. We recommend going to Mail’s Junk Mail settings and unchecking Enable blocked mail filtering. Please also make sure that Enable junk mail filtering is unchecked. If you have an iPhone or iPad, also make sure that the sender is not blocked there.
  5. Your mail client may be moving all incoming messages to the spam mailbox because of a setup problem. Please see the Why is every message going to the Spam mailbox? section.
  6. SpamSieve might have classified the message as spam. You can see whether it has done this by using the Log command and looking for a Predicted: Spam entry for the message.
    How could this happen when you had trained similar messages as good? If you train a message as good and then subsequently train a message from that same sender as spam, SpamSieve will disable the allowlist rule and add a rule to the blocklist. Then SpamSieve will classify messages from that sender as spam until you train another one as good. At that point, there will be rules on both the allowlist and the blocklist, both disabled, so SpamSieve will determine whether messages are spam by looking at their complete contents. If you don’t want it to do this, but to instead treat all the messages from that sender as good, you can add the sender to your address book or find the sender’s rule in the Allowlist window and click the checkbox to re-enable it.
You can contact technical support at spamsieve@c-command.com. Before sending your message, please read the What information should I include when I report a problem? section. Make sure that you’ve included all of the general information, as well as the items requested in the If you have good messages in your Spam mailbox section.
