7.12.1   Where is SpamSieve’s menu bar icon?
menu bar icon popover
If you don’t see SpamSieve’s icon in the menu bar, first make sure that Show menu bar icon is checked in SpamSieve’s Settings ‣ Advanced window.
Make sure that SpamSieve is checked in System Settings ‣ Menu Bar ‣ Allow in the Menu Bar (macOS Tahoe 26 and later).
If you still don’t see it, the SpamSieve menu bar icon might not be visible if you have lots of other icons shown or if your Mac has a smaller screen. If there isn’t enough space to show the SpamSieve menu bar icon:
It’s also possible that it’s been hidden by a third-party menu bar manager such as Bartender.
