There are four basic steps to installing and using SpamSieve:
- Put the SpamSieve application in your applications folder. This is
described in the Installing SpamSieve section.
- Set up your mail program to use SpamSieve to filter your mail. This is
described in sections 3.1 through 3.11 (below) and in the Legacy Mail
Programs section (e.g. for Microsoft Entourage). Find the section below
that corresponds to the mail program that you’re using.
- Train SpamSieve with some examples of your spam and good messages,
as described in the Do an Initial Training section. (This step is
optional but highly recommended. You can skip it if you don’t have
any saved spam messages.)
- SpamSieve will launch automatically when new mail arrives. It will
examine each incoming message and move the spam messages to a
separate mailbox. In order to keep SpamSieve’s accuracy high, you’ll
need to tell it about any spam messages that you find in your inbox
or good messages that you find in your spam mailbox. This is
described in the Correct All Mistakes section.
You can return to this page at any time by going to SpamSieve’s Help menu
and choosing Setting Up and Using SpamSieve. The Help menu also contains
a PDF version of this manual, which is easier to search and print.
The rest of this manual contains detailed information about how SpamSieve works
and how it can be customized. If you have a question, it’s probably answered
here. However, following the above four steps is all most users will need to do
to effectively use SpamSieve.
