3.3.2   Training SpamSieve
To train SpamSieve with spam messages, select one or more of them and then choose SpamSieve - Train Spam from Entourage’s Scripts menu. To train SpamSieve with good messages, select one or more of them and then choose SpamSieve - Train Good from Entourage’s Scripts menu.
images/entourage-scripts.png
The keyboard shortcuts for these commands are Command-Control-S and Command-Control-G.
Note that due to the way Entourage’s AppleScript interface works, you may not be able to train SpamSieve by selecting messages in mail views. Instead, select the messages in their actual folders. Also, the training commands do not move IMAP messages to/from the spam folder as they do POP messages.
Make sure that you correct SpamSieve’s mistakes by using the commands in the Scripts menu—do not click the underlined blue text to indicate that a message is not spam.
