SpamSieve colors spam messages in Outlook using one of two categories:
- Junk
- This is for messages that you mark as spam (using the SpamSieve - Train as
Spam command) and for most incoming messages that SpamSieve thinks are
spam.
- Uncertain Junk
- This is for incoming messages that SpamSieve thinks are spam, but whose
scores are below the uncertainty threshold. For more information about
scores and uncertainty, see the Uncertain Spam Messages
preference.
To change the colors associated with these categories, choose Message ‣
Categorize ‣ Edit Categories….
To turn off the uncertain spam feature, so that all spam messages are marked
using the Junk category, use the SpamSieve - Change Settings command.
Outlook 2011
Normally, both Junk and Uncertain Junk messages are put into the same
Junk E-mail folder. It is also possible to separate the messages by
category. To do this:
- Create a new folder in Outlook called Uncertain Junk.
- Create a third rule called SpamSieve - Move Uncertain Messages.
It should say “If Category Is Uncertain Junk, Then Move message
Uncertain Junk.”
- Drag the new rule between the SpamSieve - Set Category and
SpamSieve - Move Messages rules.
