Contents  SpamSieve Manual  Technical Support
7.2.4   Sending in False Negative Files
In the Advanced tab of SpamSieve’s Preferences window, make sure that Save false negatives to disk is checked. When you train a message as spam that SpamSieve thought was good, it will save that message as a file. Click the Show button in the Preferences window to open the folder. You can then drag the folder (or particular files in it) into the message window in your e-mail program. You can use Quick Look to view the message files to help find the ones that you want.
If a spam message gets through and is not saved in the False Negatives folder, this likely means that there is a setup problem and that SpamSieve was not given an opportunity to filter that message. Please see the Why is SpamSieve not catching my spam? page for information about how to fix setup problems.
