← → ↑ Contents SpamSieve Manual Technical Support
- Powerful Bayesian spam filtering results in high accuracy and almost no
false positives. It adapts to the mail that you receive to get even
better with time. Some other e-mail programs include Bayesian filters,
but SpamSieve is more accurate.
- Integrates with your e-mail program for a superior user
experience. Plus, you get the same great filtering if you ever switch
e-mail programs or use more than one at a time.
- SpamSieve works with any mail provider/host. It filters all your mail
accounts. There is no extra charge for additional addresses or devices.
- SpamSieve running on your Mac can keep the spam off your iPhone/iPad,
and you can even train SpamSieve from afar.
- Colors show how spammy each message is, so you can quickly focus on
the borderline ones if you want to check SpamSieve’s work.
- Integrates with the macOS Contacts app so that messages from friends
and colleagues are never marked as spam.
- Automatically maintains a blocklist so that it can instantly adapt to
spam messages sent from particular addresses, and catch 100% of them.
- Automatically maintains a whitelist to guarantee that messages from
particular senders or mailing lists are never marked as spam, without
cluttering your address book with these addresses.
- You can customize the whitelist and blocklist, adding sophisticated
rules that match various message headers, or the message body. The
rules can match text in a variety of ways, including using regular
expressions.
- Can use the Habeas Safelist, which indicates messages that are
not spam, as well as the “ADV” subject tag indicating that a message
is spam.
- Many spammers encode the contents of their messages so that filters
cannot see the incriminating words they contain. SpamSieve can decode and
look inside these messages. Optionally it can mark them all as spam, on
the theory that legitimate senders do not try to obscure their messages.
- SpamSieve keeps track of how accurate it is, how many good and spam
messages you receive, and how these numbers change over time.
- Turn off new-mail notification in your e-mail program, and let SpamSieve
notify you only when you receive non-spam messages.
- The corpus window and log let you see how each spam message was
caught.
- Unlike server-based spam filtering services, your mail data stays on your
own Mac, so your privacy is preserved.
- SpamSieve supports AppleScript, so you can connect it to additional
apps and fully integrate it into a custom workflow.
