Results 1 to 3 of 3
Thread: Folder names problem
  1. #1
    Default Folder names problem
    Hi, I'm evaluating Eaglefiler and finding a lot of things I like. Nice work so far.
    I found a problem when I tried to create a folder with a '/' in the name. It creates the folder with only the text after the '/'. If you try and create a folder that ends with '//' it will create a folder with the name '-1'.
  2. #2
    Default
    Sorry about that. I've fixed the bug for the next version. It looks like you've turned off e-mail from the forum; contact me at eaglefiler@c-command.com and I'll send you a pre-release build that includes the fix.
  3. #3
    Default
    EagleFiler 1.1 fixes various bugs related to using "/" in file and folder names.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
