Results 1 to 4 of 4
Thread: Problem with MailPluginFix ?
  1. #1
    Default Problem with MailPluginFix ?
    I used the "MailPluginFix" app from http://code2k.net to allow MailUnreadMenu to work (which it now does). But shortly after, SpamSieve 2.9.13 would not work: it slowed Apple Mail down so much that I had to delete the program and all its entrails from my system.
    Was it the result of installing the "MailPluginFix" app? If so, would SpamSieve work if I installed it AFTER I installed ""MailPluginFix" app? Or are they just not compatible? Or, perhaps it was just SpamSieve?
  2. #2
    Default
    Quote Originally Posted by aquares View Post
    I don’t recommend doing that because by “fixing” it you are now running plug-in code that has not been tested on this version of Mac OS X.
    There are no known problems like that between Mail and SpamSieve. The installation order shouldn’t matter. As to what caused the slowness on your Mac, we would need to measure. Please see Sending in a “Sample” Report.
  3. #3
    Default erm..
    So you're saying you know of no reason why SpamSieve and the "MailPluginFix" app shouldn't co-exist ?
  4. #4
    Default
    Yes.
Similar Threads
  1. Uninstall problem
    By Franko40 in forum SpamSieve
    Last Post: 08-07-2013, 01:37 PM
  2. Problem with Bookmarklets
    By Frajacumen in forum EagleFiler
    Last Post: 12-19-2010, 11:36 AM
  3. Searching problem
    By LarryB in forum EagleFiler
    Last Post: 04-05-2010, 02:45 PM
  4. SIMBL problem
    By calnel in forum EagleFiler
    Last Post: 12-07-2009, 05:53 PM
  5. problem with upgrade
    By jasonchao in forum SpamSieve
    Last Post: 09-17-2008, 05:15 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
