Results 1 to 2 of 2
Thread: SpamSieve and IMAP-Acc using SpamAssassin
  1. #1
    Default SpamSieve and IMAP-Acc using SpamAssassin
    Hi Michael,
    I'm using the trial version of SpamSieve and really am considering to buy it, since it's already catching most of my spam messages after only a few days.
    The only problem I've got is when I use it with the IMAP-Account that is running SpamAssassin. I've manually added a blacklist rule that tells SpamSieve to block every message that contains "Spam detection software, running on the system". The rule works fine, if I manually apply rules in AppleMail (control-apple-l), but it doesn't work when it runs the rules automatically every time I get mail. The SpamSieve rule is already on top of the other rules. Have you got an idea what I could do?
    Barbara
  2. #2
    Default Solved it!
    Sorry Michael,
    I finally understood what was the problem: My ISP configured the SpamAssassin E-Mails to be moved in a folder named "Junk". This caused them to be displayed in my intelligent folder "New messages", because I didn't exclude this folder from being showed. Everything is perfect. Should have checked this before posting...
Similar Threads
  1. SpamAssassin
    By attaboy in forum SpamSieve
    Last Post: 11-30-2006, 01:03 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
