Sometimes spammers forge one of your e-mail addresses and send you spam messages that appear to be coming from yourself. If SpamSieve is not properly configured, these spams will keep coming into your inbox even after you train them as spam. Once you fix the configuration, SpamSieve will be able to catch these messages as easily as any other spams.
SpamSieve has a feature specifically for catching this kind of spam. For messages sent from your address, SpamSieve will ignore the fact that your own address is in your address book. It will apply its normal Bayesian filtering engine to examine the entire contents of the message and evaluate whether it is spam. To use this feature, you need to do two things:
Make sure that Exclude my addresses is checked in SpamSieve’s preferences. This tells SpamSieve to pretend that your address is not in the address book, thus bypassing the Use Mac OS X Address Book safety feature (but only for messages sent from one of your own addresses).
Tell SpamSieve which addresses are yours. You do this by listing them on your card in the Address Book application.
If the addresses are already entered in your e-mail program’s preferences, you can quickly add them by choosing Update Address Book “Me” Card from the SpamSieve menu. If you have other addresses, you’ll need to add them manually from the Address Book application. Add the addresses to your card, making sure to enter them in the e-mail address section rather than the phone number section.
Your card is the one that has your name and photo (or login image). It says “me” on top of the photo, and in the name list it has a black silhouette of a head and shoulders instead of a white address book card. To find your “me” card, choose Card ‣ Go to My Card. If you don’t have a “me” card, you can make one by creating a new card with your name and addresses and choosing Card ‣ Make This My Card.
