You can choose SpamSieve - Change Settings from Outlook’s Scripts menu
to customize SpamSieve’s behavior in Outlook.
The settings are:
- Should “Train as Spam” mark the messages as read?
- When you use “Train as Good” on a message in the spam folder, should
the message be moved back to the inbox?
the message be marked as unread?
- Should incoming spam messages be marked with category “Uncertain
Junk” rather than “Junk” if SpamSieve thinks they are not as spammy?
