You can choose SpamSieve - Change Settings from Entourage’s Scripts menu
to customize SpamSieve’s behavior in Entourage.
The settings are:
- Which folder should spam messages be moved to when you use “Train
Spam”?
- Should “Train Spam” mark the messages as read?
- When you use “Train Good” on a message in the spam folder, should
the message be moved back to the inbox?
the message be marked as unread?
- Which folder should incoming spam messages be moved to? (This only
affects POP messages. For IMAP and Exchange messages, you would need
to modify the SpamSieve - Move Messages rule.)
- Should incoming spam messages be marked as read?
- Should incoming spam messages be removed from the mail server?
- Should incoming spam messages be marked with category “Uncertain
Junk” rather than “Junk” if SpamSieve thinks they are not as spammy?
