Previous Next  Up  Table of Contents  SpamSieve 2.9.28 Manual  Technical Support
6.1.4   Use Entourage/Outlook address book
With this option enabled, SpamSieve will never predict a message to be spam if its sender’s e-mail address is in the the contacts list for Entourage or Outlook. When you install SpamSieve, you should click the Load button to make SpamSieve read in the addresses in the Entourage or Outlook address book. The addresses are loaded into SpamSieve’s memory and stored in its preferences file, but they are not displayed in the Whitelist window because they are not whitelist rules.
Re-loading Addresses
Whenever you add addresses to the Entourage or Outlook address book, you should go back to SpamSieve’s preferences and click Load so that SpamSieve learns about the new addresses. (This is not necessary for addresses that have already sent you e-mails, as SpamSieve will automatically see those messages and add the addresses to its whitelist.)
If you remove addresses from the Entourage or Outlook address book, you should hold down the Option key when clicking Load; this tells SpamSieve to forget the old addresses before loading the new ones. Do not click Load while Entourage or Outlook is downloading and filtering mail, as this may cause it to freeze.
Your Own Addresses
If you have Exclude my addresses checked, addresses on the macOS Contacts app’s “Me” card will not be checked against Entourage or Outlook’s address book. This helps prevent forged spams from getting through. For more information, please see the How do I make SpamSieve catch spams sent from my own address? section.
Multiple Identities
If you have multiple Entourage or Outlook identities, you can load the addresses into SpamSieve in sequence. Click Load, then change to another identity and click Load again, etc.
Sync Services
Prior to Mac OS X 10.8, Entourage and Outlook could automatically synchronize their address books with the system address book using a technology called Sync Services. SpamSieve could access the system address book directly, so there was no need for SpamSieve to load the addresses from Entourage or Outlook. As of Mac OS X 10.8, Apple has deprecated Sync Services, and customers report that it no longer works reliably. Thus, it is recommended that you use the Use Entourage/Outlook address book option instead.
If you have Mac OS X 10.6 through 10.7, you may prefer to use Sync Services since it is more automatic. If you have Outlook:
Open Outlook’s Preferences window and click on Sync Services. Make sure that Contacts is checked and that it’s set to sync with On My Computer. This will let Outlook to sync its contacts with the macOS address book so that SpamSieve can access your addresses and know from the start that your regular contacts aren’t spammers. (If the Sync Services list is empty, see this page or this page.)
If you have Entourage:
Open Entourage’s Preferences window. If you see an option in the General Preferences for Sync Services, select it and make sure that Synchronize contacts with Address Book and MobileMe (or .Mac) is checked. This will cause Entourage to sync its contacts with the macOS address book so that SpamSieve can access your addresses and know from the start that your regular contacts aren’t spammers.
