Please Contact Us
If you are considering uninstalling SpamSieve because you’re having trouble using it or it doesn’t seem to meet your needs, please see this page or contact us at spamsieve@c-command.com. We’re happy to help get you up and running and always looking for suggestions for how to improve SpamSieve.
Temporarily Disabling SpamSieve
To temporarily disable SpamSieve, you can just uncheck the SpamSieve rule(s) that you created in your mail program. This is a quick way to turn it off if you don’t want your mail to be filtered for a while. For example, it can be helpful to turn off spam filtering while you are troubleshooting your other mail rules.
Removing SpamSieve’s Application Files
If you are using Apple Mail, first choose Uninstall Apple Mail Plug-In… from the SpamSieve menu.
To completely uninstall SpamSieve, first quit your mail program and SpamSieve. (If SpamSieve’s Dock icon is hidden, you can first show it in order to quit SpamSieve—or restart your Mac, which will automatically quit SpamSieve.) Then delete the SpamSieve application file in your Applications folder.
Additionally, follow the instructions below that are specific to your mail program:
Apple Mail
If you already chose Uninstall Apple Mail Plug-In… from the SpamSieve menu, you can skip these steps.
Or, to manually uninstall, follow these steps:
If you are using a single Mac, make sure that you’ve deleted the SpamSieve rule in Mail’s preferences (described in Setting Up Apple Mail). If you are using multiple Macs and wish to continue using SpamSieve on one of the others, you wouldn’t want the deletion to propagate through iCloud, so you should uncheck the rule rather than deleting it.
Quit Apple Mail.
Delete these files:
/Users/<username>/Library/Mail/Bundles/SpamSieve.mailbundle /Users/<username>/Library/Mail/SpamSieve/ /Users/<username>/Library/LaunchAgents/com.c-command.SpamSieve.LaunchAgent.plist /Users/<username>/Library/Application Scripts/com.apple.mail/Launch SpamSieve.scpt
See the How can I open the Library folder? section for how to get to these files. After opening the Library folder, drag the three items above to the trash. If you do not do this, Mail will report an error saying that it could not find SpamSieve.
As an example, to remove the first file, open the Library folder. Inside the Library folder there is a Mail folder. Inside of that is the Bundles folder. Inside of that is the SpamSieve.mailbundle that you should drag to the trash.
You can optionally re-enable Apple Mail’s built-in junk mail filter from the Junk Mail tab of its Preferences window.
Airmail
Uncheck the Enabled checkbox (described in Setting Up Airmail).
GyazMail
Delete the SpamSieve rule (described in Setting Up GyazMail).
MailMate
Uncheck SpamSieve (described in Setting Up MailMate).
Mailsmith
Uncheck Use SpamSieve (described in Setting Up Mailsmith).
Outlook 2016
Delete the SpamSieve script files in the folder:
/Users/<username>/Library/Scripts/Applications/Microsoft Outlook
Outlook 2011
Delete the SpamSieve script files that are located in the Outlook Script Menu Items folder inside Microsoft User Data (which is probably in your Documents folder).
Additional scripts are located in the folder:
/Users/<username>/Library/Application Support/Microsoft/Office/Outlook Script Menu Items/
See the How can I open the Library folder? section for how to get to this folder.
Postbox
Choose Add-ons from Postbox’s Tools menu. Click the remove button next to SpamSieve Postbox Plug-in.
PowerMail
Go to the Spam filter assistant (described in Setting Up PowerMail).
Removing SpamSieve’s Data Files
You can optionally delete SpamSieve’s data files, which are stored at:
/Users/<username>/Library/Application Support/SpamSieve /Users/<username>/Library/Preferences/com.c-command.SpamSieve.plist /Users/<username>/Library/Logs/SpamSieve/
See the How can I open the Library folder? section. If you delete these files, you will have to re-train SpamSieve if you reinstall it.
Legacy Mail Programs
These are the files to remove for other mail programs:
Emailer
The scripts are located in Emailer’s AppleScripts folder (next to the Emailer application).
Entourage
The scripts are located in the Entourage Script Menu Items folder inside Microsoft User Data (which is probably in your Documents folder). Go to Entourage’s Tools menu and select Junk E-mail Protection… (or Junk Mail Filter in Entourage v.X) and re-enable Entourage’s junk mail filter.
Eudora 6
The plug-in is located at:
/Users/<username>/Library/Application Support/Eudora/PlugIns/SpamSieve Eudora Plug-In
After uninstalling the SpamSieve plug-in, you can re-enable Eudora’s own junk mail support. Control-click on Eudora, choose Show Package Contents, and move the files between the PlugIns and PlugIns Disabled folders.
Eudora 5
Delete the SpamSieve Eudora Helper file and also run the Uninstall Eudora Helper program that came with SpamSieve. (To access the uninstaller, choose Show Other Scripts from the SpamSieve menu.)
Outlook Express
The scripts are located in the Script Menu Items folder inside Microsoft User Data (which is probably in your Documents folder).
Thunderbird
Choose Add-ons (Extensions if you have Thunderbird 1.5) from Thunderbird’s Tools menu. Select SpamSieve Thunderbird Plug-in in the list. Click the Uninstall button.
