As described in the Correct All Mistakes section, you need to tell SpamSieve about messages that it misclassified so that it can learn from them. Also, the sooner you correct SpamSieve the better. This presents a problem if you’re going to be away from your Mac for a while, e.g. if you’re on a trip and using your iPhone/iPad or Web mail. With the normal setup, you can leave SpamSieve running on your Mac at home, and it will clean the spam out of your inbox, but aside from remote-controlling your Mac there’s no way to train SpamSieve.
The drone setup lets you run SpamSieve on one Mac and train it from other Macs, PCs, or iPhones. This setup requires Apple Mail, MailMate, or Microsoft Outlook 2011.
Here’s an outline of how it works:
To set up the spam filtering drone:
Make sure that all the computers are set to connect to your mail account via IMAP, iCloud, or Exchange.
This optional step will hopefully keep SpamSieve running if there’s a power failure while you’re away from your drone Mac. Open System Preferences. In the Users & Groups pane, set Mail or Outlook as a login item for your account. Under Login Options, enable automatic login. In the Energy Saver pane, set it to Restart automatically after a power failure. (This option is not available on all Macs.)
Create two additional mailboxes in each mail account: TrainGood and TrainSpam.
Note: If you don’t mind (or in fact prefer) having all of your spam go to one account’s Spam mailbox, you can instead create a single pair of training mailboxes in that account (and not create a Spam mailbox in each account). However, this may make it more cumbersome to move messages into the training mailboxes (e.g. from iOS or Webmail).
Continue following the instructions below for Apple Mail, MailMate, or Outlook.
