This section is a continuation of the Setting Up a Spam Filtering Drone
instructions for people using MailMate 1.7.1 or later.
- In MailMate’s Settings window, click on the General tab and
make sure that next to Experimental 2.0 Features, the Enable box
is checked.
- In MailMate’s Settings window, click on the Security tab and
make sure that next to SpamSieve, the Enable box is checked.
- For each TrainGood mailbox, select the mailbox:
- Go to the Mailbox menu, and choose Edit Mailbox….
- Click on the Rules tab of the TrainGood window.
- Click the + button at the bottom of the window.
- In the Description, enter Remote Good Training.
- At the bottom of the window, create two actions:
- Set Tag: Not Junk
- Move to Mailbox: Inbox
- For each TrainSpam mailbox, select the mailbox:
- Click on the Rules tab of the TrainSpam window.
- In the Description, enter Remote Spam Training.
- Set Tag: Junk
- Move to Mailbox: Junk
- MailMate will check the Train mailboxes according to the
Synchronization Schedule in the Mailbox menu.
