Go Back   C-Command Forums > EagleFiler
Reply
Thread Tools Display Modes
Old 02-03-2010, 11:33 AM   #1
whardy7
Default Search - exclude emails?
I just increased my dependence on EagleFiler by adding emails - about 4000 of them. It is a great solution and one that I hadn't even touched, though I have found EagleFiler indispensable even before that.
My only problem is that now when I do a search the vast majority of my results are emails that I have to pour through, which is never what I am looking for. What is the best way to search and exclude a type of file or a folder/set of folders? I already use smart folders, but these are searches that are different everyday.
whardy7
Old 02-03-2010, 11:51 AM   #2
Michael Tsai
Developer
Default
Quote:
There are several different ways you could do this depending on what you want to search:
  1. To search everything in the library except e-mails, uncheck View > Show > Messages in Records Source and then search Records.
  2. To search files with a particular tag, uncheck View > Show > Messages in Tag Sources and then search the tag.
  3. To search just a folder, search the folder; e-mails are automatically excluded.
  4. To search a folder and its subfolders, create a smart mailbox, uncheck mailboxes, and set it to show “Every record.” Then, when you need to do your daily search, click on the smart folder and search from the toolbar.
Old 02-04-2010, 10:12 AM   #3
whardy7
Default
I would say that just about covers it! I promise I looked at the manual first, but did not see that. Primarily, doing a search in the PDF for "Search" I did not see any of that listed there.
Thanks for the great support. Still looking forward to being able to use Options on other forms of capture. Thanks for adding it to the future list.
whardy7
Reply
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Exclude my addresses MrChris2U SpamSieve 5 08-02-2009 12:41 PM
Search should search tags as well edalzell EagleFiler 3 10-16-2008 06:04 PM
Search anywhere doesn't search tags? phren0logy EagleFiler 8 10-16-2008 05:09 PM
Error on some emails efjedi EagleFiler 4 07-02-2007 03:26 PM
gif emails beluga SpamSieve 10 05-04-2007 12:57 PM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
