#1 |
I try to import IEEE Journal files (pdf) like 'yyyynnpppp.pdf' (year, issue number, page).
EF's Info Inspector shows their info like [title] : title of Journal [from] : authors of Journal for ONE group of files, however, shows like [title] : yyyynnpp (file name itself) [from] : empty for another group of files. I guess this difference comes from different pdf format somehow. And so, if I know about what kind of way EF extracts such info from pdf file, I can import them (9700 files : 7 GB) with correct info via appropriate Script. Please suggest any information or hint about this. |
#2 |
Developer
#3 |
Thank you for kind reply as always.
Your information has made 1st step forward to get the same results as Mendeley. I will try to make script according to your previous suggestion in this forum. Regards, |
#4 |
Developer
Also, if the PDF’s title field is empty EagleFiler will use the filename.
#5 |
Thank you for additional advice.
Is there any way to get info from pdf files that have standard expression (title, authors, abstract, ...) with file name as yyyynnpppp.pdf. Practically, I have to make script for that purpose? |
#6 | |
Developer
Quote:
#7 |
Using mdls command, I can extract the title and author automatically from kMDItemTitle and kMDItemAuthors even in the case of yyyynnpppp.pdf.
Thank you for your kind advice, that is truly helpful for beginners of EF and OSX like me. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Info Panel | sychou | EagleFiler | 2 | 11-13-2008 10:19 AM |
| Automating Web Snippet Info | davet | EagleFiler | 10 | 10-28-2008 02:24 PM |
| show iCal info | talazem | EagleFiler | 4 | 10-16-2008 04:08 PM |
| Tags not sticking in Info Inspector | cdavisjr | EagleFiler | 2 | 06-03-2008 03:10 PM |
| tagging and info for folders | talazem | EagleFiler | 2 | 12-16-2006 11:24 AM |
