Go Back   C-Command Forums > EagleFiler
Reply
Thread Tools Display Modes
Old 01-26-2010, 02:48 PM   #1
soulbarn
Default DevonThink import doesn't work (is it supposed to?)
According to EF support's "Applications That Support Capture Page," Eagle Filer, when interacting with DevonThink, "Captures the selected items, preserving the comments."
However, I get an error message:
Any thoughts on what's going on?
Old 01-26-2010, 03:43 PM   #2
Michael Tsai
Developer
Default
Are you using the DEVONthink Pro beta? It declares itself as a different application, and EagleFiler doesn’t know about it yet. You could try putting the attached script in the folder:
/Users/<username>/Library/Application Support/EagleFiler/Capture Scripts/
File Type: zip com.devon-technologies.thinkpro2.scpt.zip (6.6 KB, 4 views)
Old 01-26-2010, 04:05 PM   #3
soulbarn
Default
yep, using the beta - and the script worked. Thanks.
- dan
Reply
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
EF vs DEVONthink Pro ginopiazza49 EagleFiler 17 08-15-2010 10:24 AM
import from devonthink error anika200 EagleFiler 5 02-11-2009 12:16 PM
Import doesn't work the way it used to RFBriggs EagleFiler 13 11-20-2008 04:32 PM
EagleFiler vs Devonthink Investig8 EagleFiler 5 08-19-2007 05:06 PM
featurewish (switching from DevonThink to EF) macsterdam EagleFiler 20 01-14-2007 01:41 PM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
