Go Back   C-Command Forums > EagleFiler
Reply
Thread Tools Display Modes
Old 11-27-2009, 03:31 PM   #1
nonsequito
New Member
Default Searchable PDFs
Question from a trial user:
I have many PDFs of books I do in my research. Is there a way to get them into EF in a searchable way?
Thanks
Old 11-27-2009, 09:55 PM   #2
Michael Tsai
Developer
Default
Quote:
If the PDFs contain text, EagleFiler can search them. If the PDFs only contain images, you would need to run them through OCR software, which adds a text layer that EagleFiler and other PDF software can read.
Old 11-30-2009, 07:07 PM   #3
bob
Default
ABBYY FineReader and Acrobat can OCR PDFs into Searchable PDFs (text overlay)
Old 11-30-2009, 07:30 PM   #4
Michael Tsai
Developer
Default
Another option is PDFpen.
Old 12-14-2009, 11:08 PM   #5
CTS
Default Ocr
I am always confused by the topic of OCR. My Brother printer/scanner appears to come with built-in OCR software. By using the "Brother Control Center" I can select an OCR option and get searchable text.
At the same time, doesn't Image Capture, which comes on the iMac, provide OCR capability? I think I've used that as an alternative to the Brother stuff.
What is gained by using the other programs mentioned in this thread?
Old 12-15-2009, 05:32 AM   #6
brab
Default
Are there plans to integrate an OCR engine in EF?
If not, could someone share a script that automatically does OCR on PDFs using PDFPen on import?
Thanks!
Old 12-15-2009, 10:01 AM   #7
Michael Tsai
Developer
Default
Quote:
Image Capture does not have built-in OCR, but if you have other OCR software you can probably setup Image Capture to invoke it after scanning.
Quote:
That’s something I’m considering. Sorry, that’s all I want to say for now.
That sounds like a great idea for a script! I’ll see what I can do.
Old 12-15-2009, 01:38 PM   #8
Michael Tsai
Developer
Default
I’ve just written a script to do this, but there seem to be two bugs in PDFpen that prevent it from working. I’ve reported them to SmileOnMyMac, and I’ll update this thread when we have a resolution.
Old 12-16-2009, 05:44 AM   #9
brab
Default
Great news, thanks!
Old 02-03-2010, 08:16 AM   #10
brab
Default
I guess that no update to this thread means there has been no news on this front?
Old 02-03-2010, 09:57 AM   #11
Michael Tsai
Developer
Default
Correct. The last PDFpen update was on December 16, just one day after I reported this bug. Hopefully they’ll get to it in the next update.
Old 02-15-2010, 09:39 PM   #12
Michael Tsai
Developer
Default
The PDFpen developer sent me a workaround for the problem, so I’ve posted the OCR With PDFpen script.
Old 02-16-2010, 03:50 AM   #13
brab
Default
Great news, thanks!
I have a tiny suggestion: maybe the script could add the tag "ocred" or something similar to help finding pdfs which have not yet been ocred.
Old 02-18-2010, 11:57 AM   #14
cmoore
Default
Another solution would be to use the ocr to EagleFiler script that michael has. Make a target folder, and add that script to the folder as a folder action, have you scanner deposit the pdfs it makes to that folder, and the rest just happens. I know it works because I've been using it to scan my receipts into EagleFiler. My Backlog went away in short order with that script which is here.
Old 02-22-2010, 12:49 PM   #15
kaybee
Default
Thank you, thank you, thank you for the the OCR With PDFpen script! This was really the last feature that made me vacillate between EagleFiler and DevonThink. Now, for me, EagleFiler is a clear winner!
Old 02-22-2010, 08:21 PM   #16
kaybee
Default
There is a 20% discount on PDFpen and PDFpen Pro available until 02/28/10:
http://www.smileonmymac.com/mpu/
Reply
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Links to specific pages within PDFs marick EagleFiler 1 03-03-2008 01:15 PM
Issues importing OCR PDFs from DevonThink Pro spi EagleFiler 4 02-19-2008 03:04 PM
rotated pdfs chipbrock EagleFiler 2 11-30-2007 10:39 AM
Viewing PDFs brab EagleFiler 5 08-02-2007 04:11 PM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
