I would find it useful to be able to add metadata to folders. If, for some reason, tags are not possible, surely labeling of a folder should be? I would, for example, like to be able to color-code a folder red to know that it is high-priority. However, tagging would be even better, as one could tag with more than one tag (to know, for example, that this folder is tagged “important”, “DueTomorrow”, “lecture”, etc.).
You can tag and label folders. Just select the folder in the records list and open the info inspector.
My apologies. I was trying to do it from the library pane, which didn’t work. I guess that’s just where I’m accustomed to looking for folders, not in the contents pane. Thanks.
